puffernutter
Puffernutter
- Wiltshire
This concerns a 2000 year Renault Kangoo 1.4 petrol purchased through eBay, advertised as a “project car” with no keys (first mistake!) - it was cheap, that's my excuse!
Arrived with centre part of exhaust missing (including box), one plug lead missing and a few other parts missing.
Work Performed (on or relating to engine) to get it to start!
Auto alarm specialist re-coded the ECU and to two new keys supplied (not cheap!). The immobiliser can now be disabled and the car started. However, the car then proved difficult to start.
A new middle and rear exhaust boxes was purchased. It was then found that the catalytic converter had been modified to suit the previous exhaust and a new catalytic converter was purchased. Lambda sensor swapped from old catalytic converter to new.
New plug lead fitted. TDC sensor removed and cleaned.
Issues
The car was proving difficult to start. The multi-pin plug was removed from the ECU and cleaned (several times) and now starting is more reliably (even though the running isn't!).
When running, it will occasionally (few seconds!) run “sweetly” most of the time it runs rough, without power and a strong smell of unburnt petrol.
Work performed since engine running
Coil pack replaced twice. No change in performance.
ECU put on scanner. No error codes shown when the engine is running. TDC sensor appears to be working OK.
Compression test shows all cylinders are OK.
Fuel tank drained, cleaned and replenished with fresh fuel. Fuel filter replaced. No change
Any ideas where to go next? (Ignoring the obvious of the local scrappy - I've invested too much!)
Cheers
Peter
Issues
Cheers
Peter
and listen for change in engine note.
