I don't find it that good these days my dad swore by it i suspect it has changed with elf and safety. I have liberally applied it but it has not helped so far. Thank you most kind for the reply.Plus Gas is pretty good as n off the shelf solution, about £10 for 500ml - it goes a long way too
ATF??Acetone and atf mix, as good as anything.
It's nice in a relaxing bath after a hard day.I've found ardrox very effective.
RDX removes any seized nut.It's nice in a relaxing bath after a hard day.
Yield plenty in Australia cant find a supplier in the uk. so far will keep searching. andyIn work, we use a penetrating fluid in a can called 'Yield', It's as good as anything else I've used
Fiberglas body only the rusty bolts will be left LOL thanks but Noocy acet welding torch.verry local heat
plusgasI swear by Plusgas. It's the only stuff that's ever worked for me. And it's expensive - I wouldn't buy it if I wasn't convinced it worked
Lads at work use and swear by Revol Voler Graphited Penetrant. But also because it's free issue at work. lol
