doubleboost
- Newcastle upon Tyne England
Plus Gas Oxygen Plus. Propane / Acetyleneocy acet welding torch.verry local heat
Always works
thats my go to nowAcetone and atf mix, as good as anything.
Au contraire. There are performance tables published from real life tests. Water Dispersant (40th attempt) is at the bottom which comes as no surprise.I'll bet that nobody can show us some test data from a reliable source; these pronouncements have a large psychological element to them! Use whatever you like!
It may be easier to grind out the bobbins or plates from the glassfibre. Grind out all the rust from around the old fitting then laminate a new one into place, using some P40 to hold it still while you laminate.Anyone recommend a good release oil. Picked up a rusty lotus it has serious rust on the bolts i need to soak it for a while before even attempting to repair it.
Andy
Always works
Could you point us at what you are referring to? I really hope you mean that the tests were carried out in recognisable laboratory have been published in a peer-reviewed engineering journal, and not "Old Bangers Monthly".Au contraire. There are performance tables published from real life tests. Water Dispersant (40th attempt) is at the bottom which comes as no surprise.
While I know such a thing doesn't exist, I wish it did. The "old bangers monthly" methodology is about as good as you can expect, mind, and it does reflect real world conditions.Could you point us at what you are referring to? I really hope you mean that the tests were carried out in recognisable laboratory have been published in a peer-reviewed engineering journal, and not "Old Bangers Monthly".
I have had mixed results with mine.I was impressed with a mates induction heater.
Bob
Lads at work use and swear by Revol Voler Graphited Penetrant. But also because it's free issue at work. lol
