I meant the way he has done it is less skilled not the way it should of been done. That post did not read wellLess skilled definitely but less effort certainly not. It must of taken forever to produce that shambles of a joint splat after splat.
Yes, that's true, but you're adding 6mm to steel that is already at least 4mm. If it's worse than that I've seen them fixed by chopping off the whole of the bottom and redoing it up to the waterline, it's a pig of a job!all they need to do is remove some trim ballast to adjust I would not like the bottom of my boat 6mm because of the base rubbing as canals are not maintained very well nowadays and the s**t wear the bottoms out there are a couple of canals up here that are concrete based and the boats only have a few inches of clearance so if the canal hasnt been topped up the boats wear themselves away.
Could be worse. It could of been an 80 amp wolfOur freind used a murex tradesmig 151.
But he didn't have the gear either.i think that just makes it all the worse sardine, the old addage.. all the gear and no idea springs to mind.
The 'At least' maybe 0 mm ( or less!!) HA most people only repair when the boat starts to fill up and the bilge pump runs for too long6mm to steel that is already at least 4mm.
whats the actual function of the bit welded on?
is it a rubbing strip that may have to be replaced later?
is it on a finished boat?
would fully welding it pass any collision shock direct to the hull if it did not shear off?
if its an addition to a finished boat has a continous run been avoided because of insulation etc on interior of hull?
was it friday arternoon?
We had major issues with this one the floor was nowhere near flat and the hull had to be built corner to corner in the building it ended up 68 ft because the building was abit short I had to take one of the doors off to get it out !!Looks like a tidy job Normspanners! I'm no expert, but my landlords used to spit a hull out every ten days, so whenever I was over there I'd ask questions, as you do, and I also paid attention to their welding, which was beautiful without exception. I was constantly amazed that huge sheets of steel would be pushed in on a forklift, and ten days later this perfect hull would be wheeled out. They had an old truck front axle with the steering welded up, so that went on one end and forklift with a hook on the other and they could wheel it wherever they liked. Very slick!
the base plate wear and corrode away due to not being painted, no point as the paint doesnt last a few days because of the constant rubbing
the original plate is painted on the inside and concrete bricks or steel /lead etc is loaded on it to ballast and trim the boat,
no it is not on a finished new shell. The new pieces weld has to be sealed to keep the boat from sinking because people usually leave it till it springs a leak, because of the above reasons ,so if the new plate leaks or cracks so does the boat.
As said the thicker the better, it is just down to cost, just think what 16mm plate 70ft x6ft would cost, most are 10mm, cheap ones are 8mm we used 12mm
Ha no----------- I think the boat is going to end up a-------- subIs it called Subarc because it's going to be submerged in water?
