octo0072000
- south yorks
daft question has the timing wheel on the flywheel slipped moved
i would drain the fuel tank empty from the fuel and system fresh fuel filter new fuel and pump it through to the engine let it pump then into a container for say a couple of pints remove all injectors and see if working first
you need to go back to basics and start from scratch
first thoughts are timing then fuel or lack of flow could be fuel pump cant keep up the flow
best of luck
best of luck
