CompoSimmonite
- Werrington, Staffordshire Moorlands.
What about an, often free, greenhouse then replace glass with ply etc ?
ive adapted 2 broken sheds into one both bought as damaged for less than the new priceOne 8'x8' and one 8'x6'.
Suprisingly good condition, I take it thats the post nature cleanup picture.The hoarder that I am I genuinely forgot I've got another two freebie sheds taken from the same guy at the same time years ago. (SWMBO reminded me). Octagonal things with loads of glass and triangular OSB roof sections. They were brand new...I just had to collect.. No instructions so two jigsaws in one. Some mild rot and woodworm here and there. Nothing creosote won't cure. Hardly high security but needs must. Going to put both up on 6" high stacks of free paving slabs I think I can get.
Looks like you're sorted then, and the price is definately rightThe hoarder that I am I genuinely forgot I've got another two freebie sheds taken from the same guy at the same time years ago. (SWMBO reminded me). Octagonal things with loads of glass and triangular OSB roof sections. They were brand new...I just had to collect.. No instructions so two jigsaws in one. Some mild rot and woodworm here and there. Nothing creosote won't cure. Hardly high security but needs must. Going to put both up on 6" high stacks of free paving slabs I think I can get.
anyone? before I weigh it inI have about ten sheets of insulated boards surplus, galv steel either side with urea type insualtion,
was a cold store in a supermarket,
will make a great shed roof or even a complete shed, I used it on a flat roof before boarding and fibreglass,
each is 1.43m x 3.74m
free to anyone on here collect selby YO8
this is a sample
If you were closer I'd willing take them, shame to scrap themanyone? before I weigh it in
If you need to strengthen the floors, do so, but get the shed up and in use.Guess I could tack / screw some extra battens to deepen the bearers?
from what you have there you could have a double size shed to play with whilst also doing away with 2 panels one would be a door entrance the other just a panel or windowYes I know I'm going for the cheapest option but might have to rethink the bases for the two freebie sheds.
Creosoted them:
The plan was to raise them up simply on 6" stacks of (yet to get) free slabs.
The 8'x8' shed's floor has 45x35 "bearers":
The 8'x6' has 30x30:
Then there's the "floorboards". Between ⅜ & ½" I reckon 11mm. Tbh not a huge issue as I could cover the floor in pallet wood.
I wonder if these were meant to sit direct on a concrete slab?
Could you build a shed using the sound parts of the old shed plus the panels of the new sheds?.
Water has run down off the roof, onto the tarp and then against the shed wall. Softwood shiplap I painted in that crap water based stuff at the time. I hadn't noticed inside the shed as there's shelves against that wall, the walls are infilled with polystyrene here and there and they're stacked full to the gunwales. That and the shed is so full anyway I can't get over to that corner. God only knows if there's any damage over in that corner inside.
Much as I don't disagree with your choice of helper….might I suggest you try some Swedish death clearing, and building a geet big propa shed, twould be far more efficient than your shed jenga, which is eating into valuable public time!What I need in my life is the Alex Polizzi of DIY to advise on my storage and lack of workshop space situation, she could live in...
