Very true. My SWB was rated at 1600kg and was quite happy with a 1500kg lathe in it.Nobody only puts 1 ton on a Sprinter..![]()
Nobody only does 60 in one either.Nobody only puts 1 ton on a Sprinter..![]()
Are the new ones as fast as the original lwb ones - they were ton up weren’t they?Nobody only does 60 in one either.
Yes I could hit 100 in mine - I had several LWB and then a medium wheel base. Engine was about 140bhp.Are the new ones as fast as the original lwb ones - they were ton up weren’t they?
Good lorry with a good driver on a good run on a good day - is just below 10mpg on average.
8 wheelers tipping can't do this - but a big artic wagon on a good run - amazing really when you think your car is doing high MPG.
LWB ones were RWD. Incredible turning circle but deadly in crosswinds and no traction unless heavily laden. The medium wheelbase would carry 300kg more and was FWD. Reasonable turning circle - much better than a Crafter FWD. Traction far better - even good with a lathe in the back. Nice to drive but loads of niggly problems. Like doors not working and locking you out etc![]()
That has been going on for years, dicing with the heavies is never a good idea.I've noticed an increase in cars on the Motorway doing about 55mph, mostly sat in the middle lane. Fuel saving?
You are way off there with the truck mpg figures, truck running at max weight can be approx 10mpg, roughly 2 and a bit miles per litre.0.03 litres per mile per container. This is based on the Emma Maersk which can carry 15,000 containers.
A lorry uses 4.54 litres per mile. Now these figures are based on 20ft containers but most are 40ft. So given a lorry can carry 2x 20ft we have 2.27 litres per mile.
Summing up a container ship is 75x more efficient than a lorry. Not bad! Equivalent to a lorry doing 750mpg![]()
I put the point in the wrong place. Already corrected.You are way off there with the truck mpg figures, truck running at max weight can be approx 10mpg, roughly 2 and a bit miles per litre.
How does that point now adjusted effect the final comparison figures ship to trucks?I put the point in the wrong place. Already corrected.
I find most autos are probably about 4 to 8 mpg worse than manuals.^ Obviously a fertile subject.
So, it looks like there’s likely nothing wrong with the V40 (although I’ll check plugs/general stuff as advised), just a petrol auto not doing well with short/variable speed journeys. Overall running should be cheaper, though.
Ships about 8x more efficient. Having said that lorries don't always carry a 40ft container. You often see a single 20. In that case I would say perhaps 10 to 12x better efficiency from the ship.How does that point now adjusted effect the final comparison figures ship to trucks?
I used to sit around 55 mph in my V8 RR as that gave the best economy, but when doing recovery on the RAC rally we were given Shell fuel cards so I could cane itLots of variables and driving styles, I knew of a guy that could eek out 30mpg from a v8 petrol range rover, he was happy trollying along with the trucks on the motorway.
Bob
I would fall asleep at that speed!I used to sit around 55 mph in my V8 RR as that gave the best economy, but when doing recovery on the RAC rally we were given Shell fuel cards so I could cane it
I was once pottering down a hill on the motorway at economy speed when a 2 CV started to overtake, we hit the dip and started up the other side, I maintained my steady 55 and he dropped back.
It is not always about the length with trucks, ie a 20 and a 40ft can weigh the same amount.Ships about 8x more efficient. Having said that lorries don't always carry a 40ft container. You often see a single 20. In that case I would say perhaps 10 to 12x better efficiency from the ship.
I know a 20 foot will carry more weight than a 40 foot. My point was container ship capacity is measured in 20 footers - but lorries can carry a 40 footer. Obviously many variables - both for the lorries and ships. A guesstimate is the best that can be done but I reckon around 10x would be fairly close.It is not always about the length with trucks, ie a 20 and a 40ft can weigh the same amount.
Plus no ship is ever going to be at 100 percent capacity 100 percent of the time, with a clean hull and the right weather for max fuel efficiency, same as no truck will be 100 loaded 100 percent of the time , add in under inflated tyres/binding brakes plus the weather.
Nah flip flops would do that with 10 drivers in one weekendYou would need at least 7,500 lorry drivers![]()
