Guineafowl
- Nairn
As mentioned in another thread, I’ve swapped the Disco 4 for a 2018 Volvo V40 T3 petrol, 34,000 miles.
It’s getting the same usage, and is also an automatic, but is only doing 31.6 mpg. We got nearly that in the 3 tonne, 3L Disco. This car is half the weight and has half the engine, and is eight years newer. It’s almost bad enough to consider rejecting the car, since making the swap was mainly to reduce running costs.
I’ve checked brake discs with the infrared thermometer after a run, and they’re all under 30*C. Will check tyre pressures. Other than looking at fuel trims/MAF/MAP etc, is this to be expected from a modern car?
