Pulsarbebb
I never want to see another flywheel, will be testing the oil pump tomorrow, but i did manage to strip half the pump and the other half sounded promising
together the frame and welding wheels underneath, also used the grinder AGAIN! and wirebrushed the frame before using cold zinc primer which looks alot harder stuff than red oxide, and also put 1 coat of petter green on the frame
, basically ive connected all the fuel pieps on, filter is on and pump is on, ive bled the fuel system of air all the way up to the injector but when you tighten up the injector nut there is a loss in fuel pressure when you turn the flywheel and on the fire stroke air bubbles push out of the pump back towards the filter, but i have tightened everything possible but still no fuel pressure
