madkayaker
Pro sparkey Pro Welder
Any good the brew?
Any good the brew?
I've had one infection, not sure of the cause but I improved my cleaning and disinfection regime and seems OK now. But the other 5 brews have turned out really well, at least by the speed that they tend to disappear when friends come around
. Only made two lots in the last yr, but was on the button.Could you build a set of pumps into "banks"?
That is put several smaller pumps together driver by a larger motor similar to the one shown in the disco picture?
That way getting the volume by collectively adding smaller ones together?
I also work in the water treatment industry, we use peristaltic pumps for chemical dosing. They dont run 24/7 but I cant say ive ever heard of any pipes needing to be replaced. There isnt a great deal of friction but the pipes are stressed by the rollers, so you will need something tough/durable to withstand the constant squeezing action. If I were you i'd just give it a go and see what happens. You may find you never need to change a pipe.
BTW whats your reason for going for a peristaltic pump?
Err, sounds like your getting brewing confused up with distilling.Do a bit of brewing myself, aalthough mines clear and err a bit stronger
well you do have to brew it firstErr, sounds like your getting brewing confused up with distilling.![]()
What about a few of these? Handle the temp as they're used as oil pumps in performance engines.
Should be easy enough to dismantle.
http://en.m.wikipedia.org/wiki/Gerotor
