Peristaltic pumps
  1. madkayaker
    madkayaker Pro sparkey Pro Welder
    13,695
    Cumbria
    Any good the brew?
  2. brewdexta
    brewdexta Forum Supporter
    3,896
    Yorkshire
    Not bad, I've been brewing from raw materials for years, before I made this shiny kit I did most of it in a Burco nappy boiler (adds a bit of flavour and colour ;) ) and a plastic bucket with a thermostatic element.
    The first brew on this kit was pants, I had electrolytic action in the heat exchanger and I washed copper salts into the beer.:o I've had one infection, not sure of the cause but I improved my cleaning and disinfection regime and seems OK now. But the other 5 brews have turned out really well, at least by the speed that they tend to disappear when friends come around :D
    I do experiment quite a bit with recipes and some are better than others. My safest winning recipe is the Timothy Taylors landlord clone.
  3. Shox Dr
    Shox Dr Chief Engineer to Carlos Fandango
    15,459
    East Yorkshire
    A drop of taylors eh. Toured Theakstons and Black sheepjust before xmas, a bit different from 20yrs ago. Well the lack of freebeer was.:rolleyes:
    Do a bit of brewing myself, aalthough mines clear and err a bit stronger:whistle::laughing:. Only made two lots in the last yr, but was on the button.
    Where about in yorks are you, our local is willing to let a few of us start a mirco brewery, would be nice to see your setup 1st hand
  4. brewdexta
    3,896
    Yorkshire
    I'm over in West Yorkshire up in t'Pennines between Halifax and Burnley but not too far from the M62. PM me if you want a closer look or even take part in a brew, be warned though, I may show you my welding tackle (I said welding!). My brewing is better than my welding - I think that's probably a good thing!
  5. Shox Dr
    15,459
    East Yorkshire
    Never, I was at The Rallymans Rally, in Ogden last week.
    Thanks for the offer, I'll speak to the other lads (2 ) might have a ride over when the weather picks up. Otherwise we might out stay our welcome:laughing:
  6. brewdexta
    3,896
    Yorkshire
    Sounds like a plan - i'm down to my last 35 litres so need to brew soon :o
  7. rustyoldford Member
    42
    Wales
    Cant you but a high temp propeller assembly with drive shaft and then fit your own motor to suit ? May be the best way as i do know the medical pumps do use a platinum coated pipe to avoid chemical sticking which is quite pricey stuff the pumps are the cheap parts lol
  8. Peristaltic pumps are very good, efficient, accurate and relatively cheap to produce. In my experience working in the water treatment business the major problem is tube life. You can use pretty much any flexible tubing and it will work but for long term reliability you need tubing made for the job. £14 per foot for 1/2" tubing will buy you some of the proper tube for the job in none aggressive food grade tubing. (It's a few years since I worked in the industry but I expect prices today are similar)
  9. brewdexta
    3,896
    Yorkshire
    Hi WS
    This project is in a queue at the moment but I'll be picking it up very soon. I think platinum cured silicon tubing is the way to go, it doesn't collapse at boiling temps, its food grade and you can get it for around 4 to 5 quid a metre for 1/2" bore. I'm guessing this is probably what you used however there are loads of grades and formulations. As I'm only an occasional brewer, I can stand throwing a bit of tube away relatively frequently however if it was a working brewery then I can see getting exactly the right grade for the pump to be important,
    Cheers
    Andy
  10. Omniata
    Omniata Ham Radio Operator, IT Engineer, Welder, Arborist.
    3,189
    Poynton, Cheshire, UK, [DOP]
    Could you build a set of pumps into "banks"?
    That is put several smaller pumps together driver by a larger motor similar to the one shown in the disco picture?
    That way getting the volume by collectively adding smaller ones together?
  11. Yes you can, it is often done that way in industry.
  12. hooblah Member
    377
    south london
    I also work in the water treatment industry, we use peristaltic pumps for chemical dosing. They dont run 24/7 but I cant say ive ever heard of any pipes needing to be replaced. There isnt a great deal of friction but the pipes are stressed by the rollers, so you will need something tough/durable to withstand the constant squeezing action. If I were you i'd just give it a go and see what happens. You may find you never need to change a pipe.
    BTW whats your reason for going for a peristaltic pump?
  13. brewdexta
    3,896
    Yorkshire
    Cost, ease of priming, lack of cavitation, ease of flow control and ease of cleaning are my main reasons.
    Micro-brewery pumps are expensive, usually a pig to prime even with bleed valves, need a lot of effort to clean out the hops and grains. I've been using solar pumps (used on solar water arrays, not solar powered) as they are cheap, can stand boiling water, are relatively easy to control flow however they loose power at slow speeds, can be blocked by the odd grain, cannot be dismantled so a sod to clean and are pigs to prime.
    I've tried commercial beers pumps and they are no better, and can be a few hundred quid. So a large 3 or four rotor peristaltic pump or two made out of old brake drums seem the way to go. I shall use silicon pipe as it keeps its shape at high temps, replacing it should be easy and cheap. This is currently way down my project list but tends to get near the top after I brew, which is about 4 or 5 times a year.
    Cheers
    Andy
  14. Try pumping 100 twaddle caustic soda in cold weather, you will have problems whatever tube you use.
  15. Maker
    Maker nEw mEmBeR
    7,515
    Don't ask questions
    Err, sounds like your getting brewing confused up with distilling.:laughing::drunk:
  16. the snooper
    the snooper getting older by the day
    20,505
    Hull UK
    well you do have to brew it first :D
  17. Brad93
    Brad93 M J B Engineering
    8,843
    Essex
  18. Shox Dr
    15,459
    East Yorkshire
    No; brewing comes before the distilling;)
  19. brewdexta
    3,896
    Yorkshire
    Possibly but they would have to be food safe too. The good thing about peristaltic pumps is the only thing in contact with the beer is a bit of tube so very simple to clean, not easy to block and they are effectively self priming.
    However having effectively a Wankel engine pumping beer does appeal to me, and the double entendres alone would make it worthwhile. The first production rotary engined car was the NSU - which stands for non-specific urethritis, why would somebody name a car after VD? :laughing:
  20. Shox Dr
    15,459
    East Yorkshire
    esp when the way you pronounce your "w"s Andy:whistle: :laughing:
Advertisements
