I don't think there's a hope in hell that the plastic cover would survive anything being welded to those bolts.If it helps, here's a picture I found online of the cover in question - clearly the bolts in this picture have just been replaced!!! The tough ones to get to are behind that orange rubber hose (which comes off easily of course), but the shiny metal piece below the cover is very difficult to remove and has a "male" tube coming up that the orange hose goes onto and this interferes with the access to bolt number 11.
Stairway to misery. Unless the bolts are M10 plus forget using MIG. Let alone gasless mig or stick.
You'll want a TIG, + gas + welding helmet.
How much has the professional quoted? If the cover is plastic chances are it will still need replacement
Is it worth getting an induction heater, less damage than other heat, welding nuts on etc, possibly melt the plastic but hey ho.
You could also use liquid N2. Everything would shrink at different rates, then when it normalises might come loose, not melted plastic, but it might become brittle and crackheat is heat...an induction heater is going to have the bolt heads glowing in seconds, but for it to have any reasonable chance of working you will need to let the heat soak into the threaded area...this will almost certainly melt the plastic...
if you just heat the head up, all its going to do is increase the chance of rounding them even worse, or snapping one off...
Tried that too with some brand new grips.Can you not get a pair of QUALITY Irwin etc mole grips and get them started? Nice exposed cap bolts.
Thanks for the suggestion. I expect this is probably the best bet for success but also better for someone experienced with this sort of work, but I'll be honest I'm very wary of deliberately leaving myself with the task of getting 11 seized studs out without even the head to get purchase!Get some decent drill bits a fraction bigger than the bolt thread and drill the heads off.
Lift the cover off over the remaining 'studs' then blowtorch on the protruding bits then a stud extractor.
They were - maybe one more go with some decent quality ones then. I'll have to find a free weekend again as it involves taking lots of bits off just to get to these bolts!Were they off brand?
You need Irwin grips. Or Milwakee grips are good. Trust me it makes a significant difference
Trade it in, on something newish, with a warranty and have more free weekends!They were - maybe one more go with some decent quality ones then. I'll have to find a free weekend again as it involves taking lots of bits off just to get to these bolts!
If you can drop pipes etc away to get better access maybe you could use a small rotabroach cutters in a drill ( match the inside of the cutter to either the stub or the flange of the fastener) the fastener would then guide the cutter. Cut down until you just touch the aluminium, the cover should then lift off. Any of the heat options can then be used to remove the fasteners. The cover could be re- attached using 6mm set screws and stainless penny washers.If it helps, here's a picture I found online of the cover in question - clearly the bolts in this picture have just been replaced!!! The tough ones to get to are behind that orange rubber hose (which comes off easily of course), but the shiny metal piece below the cover is very difficult to remove and has a "male" tube coming up that the orange hose goes onto and this interferes with the access to bolt number 11.
Thanks George - I'm still a little anxious about leaving myself with 11 seized studs to remove without heads for purchase. And I have 11 new specific bolts ready to go.If you can drop pipes etc away to get better access maybe you could use a small rotabroach cutters in a drill ( match the inside of the cutter to either the stub or the flange of the fastener) the fastener would then guide the cutter. Cut down until you just touch the aluminium, the cover should then lift off. Any of the heat options can then be used to remove the fasteners. The cover could be re- attached using 6mm set screws and stainless penny washers.
