dobbslc
- Hertfordshire UK
Just my 2 pennys worth
You doing this with the engine cold? Will it start? could try taking them out when its hot,no?
Post 22 ^^^
In addition to Shedendmans 'take two' of run the engine first also try tightening the bolts before attempting loosening them. M6 screws and a plastic lid ought to mean low torque. Likewise if they go 1/4 turn or so then stop, work it back and forth gently. If the bolt/s goes springy don't go any harder you reached the yield point.Post 22 ^^^
No, I work from home, so leaving it up on stands whilst the job is done is fine.Do you need the car to get to work? If so I’d leave it to someone else. Sort of thing that can rapidly spiral out of control.
The studs with heads would still be there, plus a small section of stud and plastic, the depth of the plastic. There would be a good bit more to grip than you have at the moment.Thanks George - I'm still a little anxious about leaving myself with 11 seized studs to remove without heads for purchase. And I have 11 new specific bolts ready to go.
I see what you mean - the length of the stud that is currently inside the depth of the plastic cover. But there wouldn't be any "heads" left surely or the cover wouldn't come off?The studs with heads would still be there, plus a small section of stud and plastic, the depth of the plastic. There would be a good bit more to grip than you have at the moment.
Just a thought - what about one of those Sakertool portable welders. Or is it sacrilegious to even mention such a thing here... Would that produce less heat (ie with the plastic cover) and possibly be easier for a novice like me plus get the job done?
