W.olly
- Radcliffe, Manchester
I need to get this done as time is running out so after a waist of yesterday with sorting out a way to sharpen rill bits, i had to return a MM one to ry another jig type where you need to be a sciencetist to set it up lol.
And today getting up late i got a bit done. spent it all cutting and shutting this thing together. still needs a lot doing but it is taking shape, and now it may just be a narrowing of the top is needed, i have 1.6m width for the solar panel.
Just still a bit to wide i think,
what i ended up with, from a few angles as in some i dont like it but most i do, looks different also in the pics, It looks a lot better with the rails on
I made it way to high at first so them i can fettle it
but then i moved the top back as i didnt like the over hang on the front.
still to high so
Still to high so i dropped the front by 3 inch but the rear just 2 inch, this way i still have 6`6" head room at the rear of the canopy top
And after a few more trimmings and rails to see how it will look, the top did loo a bit high but when the rails were all fitted this made it look that bit lower.
As said the side overhang does look to much but that is giving room for a good size solar panel of around 250w, also i like the idea of fitting some down/deck lights under them to light up the gunnel at night.
At first i used 6" nails to hold the panels in place, just push them through at 45 deg angle and they hold nice while things are be altered as you can pull them out, if you dont push them down flush which just makes it harder to remove them, then, i used expanding foam and board to keep the sides inplace as it is not easy on a windy day and bits moving around, so once i got the position i set it in place, not the top though as this will be separate.
So not much done but as always, slowly but surly.
still to high so
