W.olly
- Radcliffe, Manchester
These updates are getting naff sorry. Little done today, to tired and not in the mood :'( yesterday I decided to paint the front deck as it will show up better where the imperfections are......wish I didn't now. Loads of small areas of tiny hole that need filling. Chuffed with the bow though,can't see the join from the repair.
I will be back with a bit more asap, I want to laminate the far deck and locker top asap I can't see the canopy lasting all winter. Oh and deck dràins will be done. Pics not the best sorry.
As always when i plan things they go **** up, i booked a week off for this week so i could finish the rear deck, as in the lockers, , rear deck drains and then onto the interior and insulation. Andy ( Cheshire Cat ) very kindly dropped off some 15mm copper pipe i needed to finish the locker drains, which i will be doing this week as the temps have gone up again from the weekend.
What has held me back is the weather, the rain has been so bad i have found new leaks from the windows, better now though than later, this stopped me from fitting the insulation due to the water running down the inner hull, I had to cover the windows up with some of the DPM i got for the canopy, so now i will have to let it all dry out, will take weeks if not months before i can fettle them.
So yesterday i cut the insulation ready to be stuck in place with expanding PU foam, i got this of ebay cheap aswell
, i like cheap now
5 can with cleaner and gun for £28. enough to do the lot and fill gaps here and there. I have managed to get half done today, nice easy clean job with the gun, them tubes you get on the canisters along and plastic tube are murder and no good once used a little all has to be used, with the gun it can be cleaned quick with no mess and reuse the canister later on if need be.
I held the insulation in place with short battens screwed into the inner ribs, this helps it keep level and flush for when i line it out with 4.5mm ply next. Feels good to be doing a bit again, I can honestly say i was getting a bit peeved and feel is it worth it as i hate to slack on a job, you can lose motivation.
Another thing i have been doing is debating over heating for the boat, i need to decide now as soon i will be setting out the frame work for the head and galley along with seating/berths. I just love stoves and was fitting one to my last cruiser a while back, now this one is a bit of a smaller boat but not to small for a stove aslong as it is fitted properly, years ago i spotted a Pip Squeak stove, nice looking and small and cheap, but no good control and build quality is not as good as another i was told about, a Boatman Stove, now these dont look as nice as the Pip Squeak, but a lot better built and better specs, higher max heat output, so no need to have it fully blazing to keep it toasty.
Now then the debate, a good size cupboard/cloths storage space and boiler cupboard or a stove, i have 2sqt for the either. If i go stove then i have found that i can turn the front bow locker into clothes storage and the likes, bigger aswell and dry as that will be insulated and lined. Now where to fit the boiler, mite has a new spot but need to look a bit more into that.
The stove will fitted on tiled area of the 2sqf and have a 15mm cavity against the lined out hull then 25mm fireboard or 25mm cavity filled with vermiculite. This will be on three sides unless i sit it on an angle. just planning it now infact. I will draw a plan up and see what you guys think.
Oh i need pics, ill be back
