scotto75
- Bristol
Did you check everything fitted properly before welding though? Its a mistake which is easy to make, and something I have done in the past.
Thanks for the advice Chris. I mocked everything up a couple of times. As you may be able to tell from the previous posts is that I do have a slight tendency to overthink things. I've got a mudguard to fit to a brace and I've taken a shock off and strapped the other side down to check how much movement there is, so I believe it's okay. I've also got a battery tray to go in after the mudguard, which I have to be careful to leave room for the air filter on the carb.
