Well....
That's not gone well...
Luckily I have home start so I've called for a tyre fitter...
That wheel separator is designed to go between the pair to remove the outer. my outer is off, came off no issues. my inner is welded to the hub (i cancelled the callout for the fitter as they wanted to charge me, but they couldn't tell me how much it would be. so much for home start...)
the last 30 seconds says it all. it doesnt work well and the threads stripped.
@8ob ... methinks you have more experience than me...
i got the n/s hub off and sorted the abs ring issue. but on reassembly i cant get rid of the play in the bearing!
its the 'compact bearing' design, so no adjustment. just fit hub, do nut up to 300, spin, 350, spin, 1100. but once done i can rock the disk back and forward several mm. there was no play when i started and i did not remove the bearing from the hub....
any ideas?
I don’t believe so. I could hardly miss a washer the size it would have to be..,
No, but it's the rear half of the bearing that has play and with it compressed with a bolt and 2 sockets there is side to side slop. After 10 refits and a lot of pondering, I've come to the conclusion that it collapsed when I removed tension from it and it needs a new bearing.
**Language** off
Fairly good idea, spoiled by crappy design and specs.the last 30 seconds says it all. it doesnt work well and the threads stripped.
