not sure what you mean ?I bet those grounding ring terminals are high resistance...
Finally, I also received the fan spanner today but in typical fashion it's seized on and just keeps spinning the pully on the beltI'm going to have fun trying to free it off I can just see
I asked on LR group, most are left but td5 are right hand, I tried smacking it and it just spun on the belt. I'm going to put a chain wrench on it tomorrow if I can.Check you are trying to turn it the right way, viscous fan hubs are left-hand thread. Also give the spanner a sharp whack with a decent hammer, that'll normally get them free
If it's okay I'll bring this up in the next two weeks or so for some real detail and if I get you right tinned wire will be good for exposed connectors (like the earth terminals you mentioned about) and normal wire for sealed terminals like the rest ? Hopefully that's the caseIn the above photo there are a pair of ring terminals which are crimped. They look green and thus high resistance.
Wire size is measured in cross sectional area, usually square mm or swg/awg. You find a chart with wire OD to csa, then measure the wires with a vernier. That then tells you what size new wire to buy.
Note that there is thin wall automotive cable which has a reduced thickness insulation, so a smaller OD for a given csa.
This is often not available tinned, but it you have sealed connectors, plain copper will be ok. Kojaycat is a good source of thin wall automotive cable.
Wonderful thanksyes, I would use tinned wire for exposed terminals, plain copper is okay for your sealed housings. Feel free to pm me if you want more info, I build wiring looms for offshore electronics as part of my job.
I'll message once I sort out roughly what I need. Mainly need to write down the sizes and wire colours of everything then get on to ordering and making
can't wait to get it done and fitted. I may leave the rear lights un cut till I put body on. Last thing I want is to cut them the wrong size
that'll sort that out
looks brilliant I think. Just need that final bit back and I can assemble it and drop the whole thing to be plug welded up.
Haha oh c'mon, just work hardAbsolutely fantastic work. Could you do me a small favor though? Stop! I've an '88 to restore and I'll probably spend the whole time thinking of how much better your work is!
set your goals high
Haha oh c'mon, just work hardset your goals high
Haha I wishI think you've set the bar too high for a few people!![]()
only cheap £10 ish but did the job
exciting times
Sparkies favorate tool the world over, in Paris I was asked by one of the local trades could he borrow my 'little to big dril'.great for sheet work, as are cones
