I agree......the ultimate is the surgical steel 430B or 430C....I dont see the benefit of "folding" the damascus steel....except that folding might spread the impurities
for shaving!!!???That's the power of marketing for you. My father used lino knives, which I still have. One day I'll get around to regrinding them, he was left-handed, I'm not![]()
for shaving!!!???
<edit> never mind: I missed the bit about "Stanley" in the earlier post.
I was told/read it was originally to provide a "fibre" to the steel. strings of different grades interwoven so some are ultrahard/sharp, some are "springy" to provide resilience, and some are soft to prevent snapping.
it seemed a reasonable explanation to me?
a way to create a strong, sharp, flexible blade using available techniques/materials.
nowadays, it seems to be just a decorative thing.
On the subject of blades, at what point did gillette and stanley convince us that having disposable blades was easier/cheaper than giving a knife or open razor a quick strop? I feel like we have been proper conned with this way of thinking. Then again im not a carpenter or carpet fitter so maybe there is a point to it.
Think it was a Mr Rolls who started the change .On the subject of blades, at what point did gillette and stanley convince us that having disposable blades was easier/cheaper than giving a knife or open razor a quick strop? I feel like we have been proper conned with this way of thinking. Then again im not a carpenter or carpet fitter so maybe there is a point to it.
He enclosed a wedge of cut throat razor steel in a nickel frame look up " Rolls safety razor " . It came in it's own case with two strops in the lids as each top side & bottom side was a lid. There are a couple still coming on the market is junk shops
so flogged it on the 'Bay.*I* still use a "safety" razor.My dad still uses a wilkinson saftey razor, blades are very cheap.
Funnily enough I had a shave for the first time in at least 3yrs, last night. It’ll be longer before I get another one
In this link we are given a brief history of Damask steel yet I get the feeling that the Chinese/ Japanese developed the art long before it arrived in the middle east .https://www.thoughtco.com/damascus-steel-sword-makers-169545
Damask steel looks like Damask silk weave threads and patterns .
Vikings appear to have formed thin forged round soft iron rods and plaited them, then via a charcoal fire heated ,forged & folded & welded them into superior blades .. Some such blades with fine herring bone patterns from the Viking ravages in the UK have been found after x raying swords think one may be in the Yorovik museum in York and another in Peterborough city museum ..
My own thoughts are … Yes the impurities will be spread out , so will the higher carbon flakes giving you a very consistent mix the more folds you put in it .
Japanese master sword makers folded many many times . A trained master sword maker would take several years to make a single sword apparently . They all started out with soft pig iron but learnt that the carbon from Charcoal & the forge fire could be utilised in getting a better metal if it was folded in like puff pastry & forge welded every time it was folded , Some one will have obviously noticed that doing it a certain way gave a pattern and so the art of Damask steel developed .
I also discovered whilst on holiday that you can impart carbon into a low carbon steel by keeping it in the carbonizing oven ( The Water wheel trip hammer driven forge in Devon (?) which is a reconstructed industrial blacksmith concern n a big industrial smithy
When we start mixing old tried & tested methods with new modern ones and machinery we often lose the very reason that the old ways were developed and used . Hardening & tempering using charcoal , clay paste and soft iron tempering blocks being one of the main one.
When you make a good well planned Damask you make many many elongated grains ( streaks ) of high carbon steel ( with luck and angling back slightly from the cutting edges to the handle )
On a good Damascus I guess those harden-able streaks will be so close as to be almost continuous along the cutting edge. The lesser steels are the frame if you like , a frame that these harden-able & tempered flakes are supported on , giving you hardness & a tempered cutting edge on a flexible frame.
After all if you look at a sharp blade under a 200 x to 500 x microscope you will see in reality that the edge is actually almost toothed like a saw
Its called Case hardening...or carburising...but its better when done in cyanide....that give Carbo-Nitrided which is harder...........Its like many things, the newer versions take the old way and totally undertand it before improving on it...like you say the Damascus steel is hard particles in a softer background....these days that can be done without the need to "fold" and with much better accuracy ie the %age can be controlled.
No.....but the patterns are due to the inhomogenity.....these days the dispersion can only be seen microscopicallybut do you get the pretty pattern?
Its still done but there are easier and better ways.....you can use alloy steels and case harden with Nitrogen or simply with heat..........Have you heard of KASENIT powder...they may still sell it.....thats what its for.Thanks Al , I knew about nitriding pits being used to harden crankshafts didn't realise it is considered a case hardening process . though thinking about it just now , it makes sense .
In the oven I mentioned they used coke and heated things like castings & forgings for several days , when the guide (a retired metallurgist )said it was for putting carbon in the work piece I was taken aback and said " So it's not a normalizing oven then " . " No is for adding carbon, it was only after Bessemer made his steel furnace in Sheffield that they stopped being in common use" he replied.
