The HSE stuff does not really mention bakeries, more the flour mills. It's here if you want to read it: https://www.hse.gov.uk/food/dustexplosion.htm
No / sub out to someone who knows about drives, an automation company.Sub out to an 'industrial electrician' I suppose???
most of them don't know which way round to wire a three phase machine let alone do a retrofit. I've wired VFDs before. Come on it's simple stuff.
I think Brad know better than any of us internet heros about what liability and risks he's willing to take on and where he isn't.
Some of the attitudes on here are so risk averse it's a wonder they get out of the front door in the morning...![]()
Your best bet would be speaking with the service/maintenance provider? If they are wiring it up and presumably programming it then they may have a particular type they prefer or know how to use/program?If you've not worked in the bakery industry then it's hard to grasp how slim the margins are and how tight fisted the owners can be.
My job is to order two drives, a control pendant and enclosure, and fabricate new mountings for the existing motors/new gearboxes so they can run a V-belt direct drive to the conveyor and to the gear pump.
The wiring is down to their service/maintenance provider, who is my customer.
in that case any major brand will suit because the paperwork/certification for the drive will be correct, dont over spec, just go for a simple inverter with a power rating close to the motor rateIf you've not worked in the bakery industry then it's hard to grasp how slim the margins are and how tight fisted the owners can be.
Okay - that's a bit different - but I would then suggest they need to work with stuff they already know and are comfortable with - specify something else and they will point their finger at you instead when it doesn't quite do what they want or fails all the time.If you've not worked in the bakery industry then it's hard to grasp how slim the margins are and how tight fisted the owners can be.
One week your company is a major food industry supplier the next you scrape in machines still so which is it? Or do you do everything...It's not "attitudes to risk" - as soon as you supply it to someone else, be it a massive multi-million pound new bakery for some multi-national, or a "small bakery in the **** end of Essex", the same requirements under law apply - and the same penalities apply, regardless of the bloke in charge or the bloke on the shopfloor, saying "it'll be alright mate . . "
Modify an existing machine, and changing it's method of drive and control, as this is, almost definitely brings it under the CURRENT requirements of all laws and regulations applying to machinery in the UK. consequences ranging from nothing at all, to paying for re-work to bring it up to standard, to jail time for causing injury and death.
Speaking as a Design and Development engineer for a major supplier in food industry machinery supply, rather than an "internet hero".
I have the reasonably backing of a multi-national company and it's legal team behind me - if like my dad was, you are self-employed and not quite set-up correctly . . . there goes the house to pay for any consequences of ignoring legal requirements in the supply and modification of machinery . . .
I'm also pretty sure if I knowing ignore standard regulations, that large multi-national legal team will leave me high and dry . . .
...it needs "dozens of chain drives" etc...
