ACF 50 and some grommets ...Zinctec is what I use...just to clarify you only grind off say 20cm along the weld joint itself (both sides). This is because welding with the zinc coating left on gives off toxic fumes.
£60 seems cheap...but only if you actually get what you want.
The Figaro is based on the Micra K10...I thought the scargo was the same...maybe I'm thinking of the Pao.
If the scargo rots like the Figaro the large sheet might come in handy![]()
So an update.
I have found someone who can make me them but they won't be done till Wednesday.
They have cost £60 but at least I don't have to mess around with bending them into shape.
I will update you all when I get them and let you know how I got on.
Sssssshhhhhh the someone might be watching and up the priceThat's some result!
What's the score with the 'someone'? Does't sound like a viable business's price, this Century?
The way I cut out the rust was with a 1mm cutting disc, my corners are shocking and I ended up cutting over my lines by about an inch so not very neat, I might try a hacksaw or drill circles in the corners so I don't need to get as tight. Once I cut out the rust I then use the flap disc to remove everything around it to get back to the metal, I'm sure I am now thinning what is already thin material.
Yer thats not a bad vid,now do the same with limited access,or vertically,or overhead,different ball game all togetherI found this video quite helpful showing the thin metal technique on Japanese steel (.6mm)
