Well spotted ! That could be a good deal....... If it worked, it would be £500-worth of kit there.
The wirefeed does not work. You need to get the serial number and date of original purchase from the Seller. Then contact R-Tech and check if their 5-year transferrable warranty applies. If so, click the Buy It Now quickly before someone else does !!
R-Tech will collect if from you and fix it for free.
If the warranty does not apply, R-Tech can probably still fix it, and their after-warranty prices are apparently reasonable.
In that case, if you can get there to collect it, it would be worth a punt at £200.
There is a good-quality regulator. Also a couple of auto-dim helmets, which may be in working order.
( The Seller mentions Arc welding worked, but MIG does not because of no wirefeed. Like many inverter welders, the R-Tech 180 can be used as an Arc ( MMA ) welder as well as a MIG welder.)
The gas bottle is probably not the Seller's property to sell?
I wonder why the Seller has not bothered to ask R-Tech to fix it and double the value for him....?
