Maybe he was trying to shed some light on the problem!Psst! I think you're in the wrong thread!
Led torch recommendation
Hi I'm looking for a recommendation for a led pocket torch 3 or 4 inches long,must be single mode, One click on/off. Rechargeable preferable. Thankswww.mig-welding.co.uk
alleluia it sounded complicated did you loose sleep over itView attachment 428093
Grabbed the stilsons from work and nothing applied a bit of heat (wanted to do without realy as it's been painted but)
I hardly even leaned on it and it turned and came out
nope work and life get in the way of play time and the dark nights dont help eitheralleluia it sounded complicated did you loose sleep over it
i was not going to post for another couple days and see how far the thread goesThe Eagle has landed.
I couldn't think of a more complicated way to do it. I like it.someone would have suggested putting it upright in the vice with the jaws on opposite flats of the bush....
Ahhhh Fk.Psst! I think you're in the wrong thread!
nope try to find a 1 inch to 1/4 inch reducerNow what? Clean it up and put it back in?
You could get a 1/2" pcl from Screwfix for around a fiver but maybe you want to use what you already have.nope try to find a 1 inch to 1/4 inch reducer
i can get 1inch to half inch then a 1/2 to 1/4 to put in it then a pcl xl quick release to get air out full flow as best i can after buying a new pully
Do you only have 1 outlet on the compressor tank?
I think one tapping on top of the tank is for comp pump discharge, other for a pressure guage.Have you not seen the second pic (at the start of this thread)? I see two ferrules on the tank already in use. Guessing one inlet and one outlet?
A question re your 3/4“ outlet: How long does it take to exhaust the useful air from the receiver with anything that needs a 3/4” line from a likely 5cfm FAD unit with limited storage capacity?
