Pigeon_Droppings2
- london
Lift the soaked tray out he water tray let it drain for 12 hrs or so put it back in the empty water tray and place it a bright room, but not on a windowsill with full sun where it will be far too hot . Keep it trigger pack spray moistened .
Lettuce seeds usually take 7 to 10 days to germinate. During the seed germination process, the temperature is maintained between 15 to 20°C. Once the seeds have germinated, they will turn into small seedlings with 2 to 3 tiny leaves.
That’s a special dedicated bean frame.. you like beans…
It looks like the bens are too dry in those Papier Mache pots .I started the 32 Czar runner beans off on April 12th, using some tbh horrible compost from Lidl. They were put into compostable pots.
This is the tray yesterday:
All but one have grown to varying degrees. Some strong looking ones and a few weaklings there too.
Can't help wondering if better compost would have helped?
Also there are like tiny green plants in each pot along with some mushrooms of some sort. I presume I should take these out?
A few hours soaking is far more effective than a dripple of four to ten seconds out of a watering can or hose pipe spray head , plus when there is prolonged precipitation the leaves & stems also take in nutrient enriched falling water , oxygen & CO2 as well as pollutants collected by the rain as it falls .Why is it that "rain" brings plants on better than watering, even if with stored rainwater?
I've read it's something to do with it being "charged" or something.
These days, I use my bottomless seed pots and labels with the contents and date sown. I put a single seed in the lightly compacted tube in a pencil point depth hole & cover it with a pinch horticultural vermiculite then gently water it well and stand half a dozen sown tubes in a used strawberry punnet , that way even if the tubes get mixed up I should know what is in each tube .I sowed them in three bands - one band was from some seeds that were "best before" last year sometime, the other two bands were from two different seed packets that are in date. This is the view today, I can't remember which end is which, nor how wide the bands were, so I don't really know which these are. I don't think they're radically different types anyway, I'll settle for having some lettuce of any type so hopefully they'll go further. Don't know whether to plant them in the garden or move to one or more bigger pots.
You can start such seeds in plastic egg boxes in the recesses and lift out a plug plant to transplant it with little or no root disturbance /I've moved a few of my lettuce on to a larger tray now, to see if anything comes of them. I'm not sure they will do well as I think the roots were quite entangled as the seeds were planted so close together and I may have damaged some of them. I was using a spoon and a bit of wood to separate them so as to not touch them directly, and I'm about as useful with those as I am with chopsticks. Still, plenty more still in the original tray if these go nowhere. I'll have to move the rest on soon, but once you give them enough space to grow they take up quite a lot of space.
