Most domestic "castles" would use 400 to 600 litres in 6 months..... If you're spending that much on oil, better gird your loins for leccy costs running a heat pump this winter!You heating an uninsulated castle?
His username is Knighty - so possibly a Knight and does live in a castle!You heating an uninsulated castle?
I have this T shirt……after new insulated roof, new insulated floors, underfloor wet heating, new inner wall insulation, new windows etc we now use about 2000 ltrs per year in a 3000 sq ft house.pretty much, we only moved in October, loft insulation is useless, there's a load of single glazed windows
we've sealed a lot of the draughts up now, but when we moved in you could be sitting eating your dinner and feel the wind blowing past you - windows need an upgrade but we're going to move some of them / make some bigger etc. so we're holding off on that, trying to push and get solar sorted before next winter
heat pumps will need a full new heating system in, what's in is a bodge of upgrades from the old coal powered gravity fed system, so that'll probably be next summer
fingers crossed for this year get the batteries and solar sorted then I'll get some kid of electric boiler to dump heat into the heating system
I don't know how the previous owners put up with it, when we moved in the hot water tank was heated by the return water from the radiators... and even if you did heat it up... all the heat would thermosphere out into the heating system within an hour :-s
Normally excess from solar goes into your hot water tank via the emmersion heater unless you are charging batteries, in which case batteries get charged first. A solar economiser I think its called, we dont have batteries yet, but excess solar gears hotwater first then our heat store tank
I gambled. I could have fit in 3000l. I ordered 1000 litres at 50ppl in the hope that it might continue to come down!50.1p here now , 2000L ordered.
To follow up on this;Homefuels Direct have a "Order too much & we'll automatically refund the difference." , so we'll see how well that works.
According to their system the fuel hasn't been delivered yet, so I expect a manual correction has to be done in their back office.
