octo0072000
- south yorks
I agree with 8ob my money is on a piston/head gasket not valves
Most people have a spare wheel....Broken biker has a spare car.Well I haven't had a great deal of time to work on the car today but I did manage an hour or so...
I may have found part of the problem, and I have definitely found where the oil was coming from...there Is a crack In the valve cover that the oil has been leaking through slowly...
As I started to tear into getting the head off I removed the cam belt cover and found a piece of the inlet side cam wheel as it fell out when the cover was pulled away...4 teeth have broken away from the cam wheel in a chunk...
I think the low compression may be because of a bent inlet valve if the cam belt skipped when the wheel broke...belt is still intact with no signs of damage but think I will take this opportunity to replace it and the water pump...
Going to look at another focus tomorrow as the Mrs can't afford to have time off work again if something else goes wrong, and atleast if it does go wrong with the next one I have a spare car she can use once ive sorted this one, or a full cars worth of spares if I decide not to fix this one
But is one enough?Most people have a spare wheel....Broken biker has a spare car.![]()
But is one enough?![]()
If we ever meet, please stay away from my car. Thank you x
Hallelujah!As long as it's not registered in my amen it will be fine lol
