Gate turret mill
  1. pressbrake1
    pressbrake1 pre-moderated
    990
    essex england
    I’d like a large snow grinder with some deck height which I could use for way grinding. I’d just make a vertical sub spindle for dovetail and way underside
    ronan likes this.
  2. scottmk1
    scottmk1 Forum Supporter
    838
    Scotland
    OK so I have some enquiries out about a couple of machines, one of them is an Ajax AJT1 with 3 axis CNC controlled by an Anilam 1100. Anyone know much about the Anilam setup? Capacity wise the machine isn't much bigger than the bridgeport but it does look like a good condition machine.
  3. M K Member
    489
    Essex
    scottmk1 likes this.
  4. scottmk1
    838
    Scotland
    oooohhh nice
  5. scottmk1
    838
    Scotland
    That XYZ is now sold unfortunately.
  6. M K Member
    489
    Essex
    Shame,
    If I see anything else il post it up for you
    Thanks
    Marc
  7. scottmk1
    838
    Scotland
    Thanks Marc.
  8. scottmk1
    838
    Scotland
    Next question, what about Semco CNC machines? I've seen a Semco 800 bed mill for sale at reasonable money. Although I'm not too clued up on the CNC side of things it would sure be interesting to learn.
  9. Hood
    Hood Forum Supporter
    7,915
    Carnoustie, Scotland
    I think most of these makes/types of machines will be Taiwanese.
    Nothing wrong with that, in fact probably good as Taiwanese stuff tends to be reasonable.
    Regarding the CNC control, without knowing what it is hard to say but if fairly old then it may be expensive to sort if things go wrong.
    Nothing stopping you retrofitting with a newer control whether that be something pc based like Mach3 or stand alone like the SZGH I have just fitted to the lathe.
  10. scottmk1
    838
    Scotland
    Ok cool. The controller is a GSK 983Ma-H so I've no idea if that is good or bad. I figured most machines like that are from the same Taiwanese factory.
  11. Hood
    7,915
    GSK controllers are similar to the SZGH controller and is a Chinese stand alone control. I am not sure how old that particular model is but I do know the earlier GSK controls could be problematic and were not very good compared to the newer breed of controls from China.
  12. Hood
    7,915
    From a quick search that seems to be quite a recent GSK control, still available as well so I suspect someone has recently fitted it to the mill if the mill is fairly old.
  13. scottmk1
    838
    Scotland
    I'd imagine it's about 20 years old or there abouts but thankfully doesn't seem to have accumulated much wear.
  14. Hood
    7,915
    I don't think that control would have been around then so looks like it must be a fairly recent addition.
  15. Hood
    7,915
    Looks like it may be a +/-10v analogue command control which is likely a good thing, will certainly mean it is closed loop.
  16. scottmk1
    838
    Scotland
    Thanks for the advice @Hood I assume the closed loop control systems are preferred type?
  17. Hood
    7,915
    Yes and no, well closed loop is definitely better than open loop but there are different kind of levels of closed loop.
    My Chiron for example is similar to the GSK in that the servo drives are commanded with an analogue voltage (+/-10v) and the control makes sure the axes are where they are meant to be within the error that has been set in the control. With a well tuned and set up system that is good, with a very loose and poorly set up system it may not be so good. Also with this type of feedback the control always knows where the axes are so even if you E-Stop or disable the drives and turn by hand the control will still know the position of the axes.
    On the lathe I have just fitted the SZGH control to it uses Step/Dir signals, the servo drives themselves close the loop to the motors and make sure they are where they are meant to be within the error allowance set in the drives, so basically the same except the control itself is not aware of whether they are where they are meant to be or not. The control however also has feedback and although it is not used for actual positioning it is used for position error monitoring and if the axes exceed the set error it will halt until they are within the error.
    On the lathe previously it basically had the same setup but without feedback to the control so in theory something could go haywire in the servo drive and the control wouldn't know, in reality that is unlikely but....
    On a fully open loop system like you may have with stepper motors then any positional errors will not be picked up and the control will continue to command moves which could cause collisions etc and certainly ruined parts. On a well designed and specified stepper system that however would not be very common.
  18. scottmk1
    838
    Scotland
    Well I've committed to buying the Semco mill, hopefully it'll be a bit better a machine than the bridgeport, albeit slightly less versatile. Best get learning G code!
  19. Hood
    7,915
    1000x better than a Bridgeport and even a lot better than the heavier knee mills available. :)
  20. scottmk1
    838
    Scotland
    I'm glad to hear it. Just got to figure out how to get it through my garage door now :p, well that's after I've got it home.
Advertisements
