OP has checked cylinder head temperature, using his scan tool.
But a faulty sensor, if it has one, would still supply the wrong info to the fuel ECU.
Worth a look as it sholud be relatively cheap.
Probably not but wouldnt have anything to do with the crank or cam sensors would it? The crank sensor wouldnt show up on scantool anyhow... probably not the problem but just a thought.
Do you know if this vehicle has a tank mounted priming pump and if it is working ?
from my experience you will always get 'gaps' in the fuel from the leakoff this may not actually be air but cavitation.
the only way to properly check common rail injectors on the engine is to connect a calibrated container to each of the injectors and run the vehicle and then compare the amount leaked off each injector they should be roughly equal but if any are passing amassive amount it won't start anyway, because it will not achieve the nessesary pressure to start. The air from the fuel system usually gets injected through the nozzle and thats what causes the timing to be 'out', and causes the missfire and white smoke.
I think you have answered your problem here, the pipe you disconnected I presume was the pipe that returns from the filter to the tank?, there maybe a little air there but not masses, the air was more likely in the pipe from the injection pump and the only place that can come from is the supply to it ie the filter or pipes to the pump. A diagnostic tool I use is a piece of soft clear hose in place of the various black plastic ones moving it from the supply to the filter, then from the filter to the pump etc etc.I was thinking about doing a leak test mainly so I can get an idea of what the injectors are like - incidentially I disconnected the injector return hose from the filter to get some diesel to prime the new filter, the container I used to catch the fuel filled up quickly and the fuel was full of air. I put this down to the engine not using much fuel at tickover so the pump provides a surplus supply and the air being due to the pump scavanging what ever comes back from the injectors - which I assume will be a bit of fuel and a lot of air?
If they use QR couplings and you get the correct size clear pipe it will fit in the QR and seal on the o ring, (you may need to hold it in) and you can push the other end over the steel stub the QR has come from. when you have fitted the clear pipe run the engine and look inside the pipe for air, if none move on until you see the air, this could be an o ring in a QR.
This is especially important if you do not have a primary pump! because with a p/pump you you would poss have a leak of fuel, but without a P/P the whole of the system from the tank is under a vacuum.
Word is that if you fit new injectors to the TDCi you have to reprogram the ECU with their serial numbers, or some such![]()
Although I bet a dealer would make it sound like a big job and charge accordinglyThats correct - instead of it being a simple case of injector 1 connects to plug 1 and so on you need a magnifying glass to read a long serial code on the injector and pc/diagnostic connector to program the codes into the ECU.
Actually it wouldnt be too bad - the diagnostic tool I bought from ebay does it and it cost £14.99Although I bet a dealer would make it sound like a big job and charge accordingly
how did you seal the hole in the filter ? if you didnt then it would be drawing masses of air in that hole, also you must have done that whilst it was running?The pipe I removed runs from the pump back to the filter and tank, there is a T which has the bottom leg connected to the filter (Does that make sense?)
The fuel that went into the jar was a constant stream but milky with air - not a spluttery flow of air with a bit of fuel, does that still sound like too much air?
The codes are a calibration code.
Asked earlier but question must've got missed.
How does it die? A sudden cut out, or a cough and splutter down to nothing, or a racing idle before tapering off?
Secondly, how difficult is it to restart?
If you have air in the fuel system, to the HP pump and no LP pump for priming, then I would expect it to be really difficult to restart; but, if it restarts easily on virtually the turn of the key, the fuel is clearly still at the pump and you have to ask why did it cut out in the first place?
The codes are a calibration code. Vehicle will still run fairly well with mismatched codes, but for best results you should re-code. Its all horses for courses, after 50,000 miles the injector will be so worn it makes a mockery of calibration.
I have formidable and couldn't get it to work when I tried using it to change injector codes. That was on a MK3 monde 2.0 130ps.
If you do start playing with injector codes, using formidable, I would advise you to ignore the steps relating to switching off the ignition during coding. As said I couldn't get it to work and used my Texa in the end to do it.
Also note, If you do recode injectors, vehicle should be stone cold upon first being started with the new codes. It will also run without pilot injection until driven a few miles - will sound a bit more diesel like and perhaps be a bit rough at first. After a run the ECU will get the pilot injection dialled in and its job done.
I have a transit here at the moment with bad starting have checked everything changed oil etc etc the guy has only just bought it, I told him that it should have a filter but he said that he had fitted one and it didnt need one. But the filter was just white, not genuine, So I spoke with my mate at the local ford dealers he has been there 30yrs!, he said re tranny filters that their garage do both a, genuine parts, service and an after market parts, service, BUT will not use a none genuine fuel filter for the same problems of not sealing I fitted one (RRP £ 26!!! )filled it and the thing started first compression-----
been out to it this morning and it fired first compression -------
ps have spoken to loads of 'mechanics' lately that say oh yer I fill the new filter I pour the fuel outa the old in into the new one !!!! great the old filter has saved all that crap going into the engine then you pour it into the new one ----------WTF????
from ford you have to change the whole pipe but you can on some change the o rings but it is getting the o rings an exact match to fit in there, but I have just cut the fitting off the end of the shaped pipe when they have been damaged and used standard (but good quality) push fit QRs and adapt it to the filter. To give an exampleAre the fittings easily available?
