I've got a Mk1 Focus which has an annoying problem, when its cold it wont tickover for more than about 10 - 20 seconds before it stops and while it is ticking over its really lumpy, it makes it a right pain in the **** to defrost it and a nightmare driving through town on the way home! Once I've driven about 2 miles its fine, its also fine when its hot, goes well and does 50 - 55mpg
I've had a look over it with the engine cover off and can't see anything obvious like split hoses etc, I've also bought a diagnostic reader to check for fault codes (no codes present) and the cylinder head temp, fuel temp and inlet temp all give figures which look normal
I've blocked off the EGR valve as it was stuck partially open and that stopped it smoking while driving at low speed (the valve is nightmare to take off and clean and a new one is silly money as its part of the inlet manifold)
I've changed the fuel filter for a new Delphi as the last one was of an unknown age and the tickover fuel pressure is about 230 bar (its a common rail)
I'm keen not to take it to the garage in case it ends up as a "We've fixed it and here's a 4 figure bill because we changed loads of bits!"
Any thoughts? I've done a bit of ratching on the web and so far it could be anything....
