Richard.
- Cambridgeshire
Ok yes you have a contaminantion issue going on. As we know everything from your machine down to the torch works fine from using them here I would check your gas line connector in the welder and every other joint back up to the bottle for leaks.Busy all week and only today managed to get the Tig fired up for a practise.
Wonderful how quick i have managed to revert back to my first attempt
Only things changed since last Sunday are Filler & Gas.
You need some leak detection fluid as touch and hearing senses are not good enough to pick them up.
Give your filler a good wipe with a rad dampened with cleaning solution (acetone brake cleaner etc). If all that fails it may be a case of some Micky mouse argon.
