Hossein Maleki
New Member
- Iran
Hi Bobbes, what that mean supprssorboard?supprssorboard
Thank you bobbes, I already noticed, but plz check the attached pic for 1b section, I don't have voltage on output, this is the problem.Hi Hossein, If the machine is running you don't need a testboard. Herewith the user manual. It gives you information about the LED's.
They are Amazing machines, I will hope to help if I can.
Can you weld electrode?
In first line you mentioned Arc available in second line you mention no Arc, which one is correct, I think it has internal gas flow switch, I will check again today and let you know, but need to know the situation of Arc too.
So far I know there is no gas flow switch inside this type (DTE-255))
First you can try to make a connection with a small wire between J anf K on the remote control connector. That must have the same results as the torch switch.
Hi, and thanks for the reply. I start a new thread.Hello and welcome!
Maybe your issue would be better added to an original DTD 250 thread instead of this Aristotig 400 one, such as this one:
or perhaps start a dedicated new thread?Esab Aristotig AC/DC machine
Hey, I just bought a Esab Aristotig DTD 250 AC/DC tig machine on Ebay.de. After looking for a good AC/DC machine from the big brands i decided to go for a second hand machine. This one has a water cooled torch, pulse function, 250 Ampere, inverter based, 400V 3-phase input etc etc. :welder...www.mig-welding.co.uk
