- UK
Where's your rectifier on that drawing?
The rectifier is in the same place you have indicated it on your mark up in post #116.
I have taken the 24V DC positive from the rectifier to the mushroom as per original circuit drawing; you've got the negative side going up to the mushroom.
Essentially its wired as per post #116, but the - and + are flipped over from the rectifier.
The mushroom limit works fine. I'm trying to test whether 24V is present at various positions to make sure non of the components are faulty but the tester i have is rubbish. New one on its way.
The YT vid Richard linked to is a good watch and I'm after a bit of help with the VFD to make sure its wired correctly if anyone can assist.
changed the P11 setting (and the P10 setting needed changing) and it sprung into life, all working as it should!
