wyn
- Cardiff
They look to be very useful..... what kind of money is the set?
I bought a set the other week to replace a set that had broken cutters and it was around £20-£30.
A few sites list them for £130
I have done s fair few 17 mm with hand drill but can't remember biggerThe shank is normally about 13mm but the actual drill sizes go fairly big, I know I've got a 19mm and I think I've got one that's 22mm.
Not recommended to be used hand-held though.![]()
If its 50mm box you will probably need to fab up a jig to locate and hold down onto the box with a clamp, if it grabs on the way through the mag may not hold on 50mm box x 4mm wall.
So if I use a step drill on this box it won't fly off and kill me if I take it steady?
are you on about sticking one of these,Mitcel the rota broach bits Im refering to will do your job no problem with a hand drill they are a tank cutter really with a 6mm centre bit
that id be called a hole saw.no they are made specifically to go in a hand drill they have a 6mm drill bit instead of the centre pin !
if i could do a link I would show you www. orbitalfasteners tools short handdrill tct cutters
