Gas/power port dennis, converts to a standard (U.K./Europe standard, not USA standard) 3/8bsp torch fitting...
You need to educate yourself on how air cooled/ water cooled torches hook up, plenty of YouTube stuff for that. My post isn't the place to educate you on these things.
It's the same thing inside. Plug, potentiometer, switch. Takes a bit of knowledge to put it all together and make it work. Kemppis often make life difficult though by requiring separate potentiometers to set min and max current. You don't want minimum to full power on the pedal, to tough to get the current you want. And the pedal overrides the current dial on the set so you can't use that to set maximum like some other units.
Returning to this... Have you made units for kemppi machines before? Would you happen to have any kind of schematics?
Those caravan pumps are ideal if you can get 12/24 v to them. They ain't over worked in a tig coolerCheap poorly made pumps for Tig coolers arent that great an idea, unless you are only wanting to use very occasionally. I would guess you should almost certainly be able to get a used Pro Con pump, from someone who sells and repairs vending machines. Would guess most of these pumps get scrapped, even though there are many years of life left, and parts are easily available.
