Ahh I see!Black smoke is indeed excess fuel, white smoke is incomplete combustion.
Why?Going back to your first post you stated that a saver shim was fitted, surely that would mean that all the valve clearances would have to checked and reshimed if needed ?
And why did n't you check them?, as you are a mechanic, it takes 1 minute, tops, to check, as the cam is fitted and 5mins if you have to wiz the cam cover off. I have marked up buckets and shims in the past and a couple times when mithered by phone calls or people asking just have a look at thisas I was short on time that had to wait I didn't measure the clearance on the valves.
. have got confused when dealing with stupid french cars numbered, number 4 at the front of the engine where the real number 1 lives.
Why can't they be normal? stupid idea's not on one of those they don't as basic as it goes.Not sure if the ECU adapts on them, but mine, if you change the exhaust etc, it takes up to 30 minutes of continous cruising to recalibrate itself...
If you can't see, it probably is the smoke in your eyes, that white stuff stinnnngs like crazy.Ahh I see!
I was under the understanding that the pump timing was fixed it's fitted with the Lucas/cav pump and injectors but the pump has a tag on it that looks like it says Delphi.
Vernier on them. But if pinned shouldn't need to adjust vernier, also rough idle sounds like low compression to me.Hi, there's fine adjustment between the sprocket and the pump shaft. It's either a vernier type adjustment within the sprocket or you loosen the fixings on the injector pump flange and turn the pump body itself. different manufacturers do it different ways.
And why did n't you check them?, as you are a mechanic, it takes 1 minute, tops, to check, as the cam is fitted and 5mins if you have to wiz the cam cover off. I have marked up buckets and shims in the past and a couple times when mithered by phone calls or people asking just have a look at this. have got confused when dealing with stupid french cars numbered, number 4 at the front of the engine where the real number 1 lives.
check the clearance first, then we can discuss further when we know.
Given the head upper face is used as the datum face for setting the job up, I can't see the camshaft being 'sloped' when its all re-installed.
Not Checking Flatness
Never assume a head is flat. You can’t tell if a head or block is flat or not unless you measure it with a straight edge and feeler gauge. You should always check for flatness, especially in critical areas like those between the cylinders.
Flatness specifications vary depending on the application, but on most pushrod engines with cast iron heads, up to .003″ (0.076 mm) out-of-flat lengthwise in V6 heads, .004″ (0.102 mm) in four cylinder or V8 heads, and .006″ (0.152 mm) in straight six cylinder heads is considered acceptable. Aluminum heads, on the other hand, should have no more than .002″ (.05 mm) out-of-flat in any direction. On a performance engine, the flatter the better.
If the face of an aluminum head is warped, don’t assume the only way to straighten it is to grind metal off the face until it is flat again. The whole head is warped. If the head has one or two overhead camshafts, the cam bores will also be misaligned in most cases. The best fix here is to straighten the head BEFORE it is resurfaced. This can greatly reduce or possibly even eliminate the need to remove more than a couple thousandths of metal.
Aluminum heads can be straightened by countershimming the head on a heavy steel plate (place shims under either end of the head to offset the amount of distortion), clamping it down, then heating it in an oven to about 425° F for several hours, then letting it slow cool. The goal is to get the cam bores straight. Once they are in alignment, chances are the face of the head will be reasonably flat, too, and require minimal machining to refinish the surface.
Another method for straightening aluminum heads is to use a torch to head the top of the head, starting in the center and working towards the ends. The trick here is to keep the head temperature under 500° F to prevent softening the head too much.
Why ?It can only be twist though, around the cam shaft axis. Else the camshaft would be bent once installed and would wear the journals in no time.
When overhead cam heads get hot, they often swell and bow up in the middle. This may cause the OHC camshaft to seize or break as well as cracks to form in the underside of the head. Pushrod heads are not as thick as OHC heads so are less vulnerable to this kind of stress and warpage. But even pushrod heads have their limit, and when pushed too far will also warp and crack.
Aluminum heads are especially vulnerable to warpage and cracking because aluminum has a much higher coefficient of thermal expansion than cast iron. Consequently, when a bimetal engine with an aluminum head gets too hot, the head tends to swell up in the middle, causing it to warp and blow the head gasket. If the engine has an overhead cam, the resulting misalignment in the cam bores created by the warpage can gall or seize the cam bearings, or even break the cam. Anytime you encounter a warped or cracked aluminum head, or an OHC head with a seized cam, chances are the damage was caused by overheating.
Massive generalisation to say that heads usually bow upwards in the middle.
