i just changed the large hub side boot on out car with a jubily clip. id rather it not come off on full lock using one instead of a tie wrap even at 120mph u dont get imballance. not that ive been more than 70mph mindCheers lads.
As rtb says i would have been worried about the balance as well.
Cable ties as in the plastic ones?
Are they strong enough?
its ok putting a large tie wrap on a nice clean boot and joint but when theres grease about underneath and u have to re fit they can easily pull offi just changed the large hub side boot on out car with a jubily clip. id rather it not come off on full lock using one instead of a tie wrap even at 120mph u dont get imballance. not that ive been more than 70mph mindits ok putting a large tie wrap on a nice clean boot and joint but when theres grease about underneath and u have to re fit they can easily pull off
Cheers lads.
It is my belief that one day EVERYTHING will have become held together with tie wraps![]()
the MOT tester wasn't
The garage that fitted the exhaust to my Volvo is of the same opinion,the MOT tester wasn't
he ended up using wire from a farmers fence. Got him back luckily!the tester at the station gave me a verry narrow jubilee clipYou would have to watch using a jubilee clip on the hub end as quite a few cars now dont have enough clearance for something that big. I have even had some with so little clearance that a cable tie would not fit.
Oddly I have been replacing a CV boot today on a Rover 25.
Cheated used a split boot. Makes it a nice quick job & they last much longer now than they used to.
I own a little microcar and there is not enough Clearance to fit a jubilee clip or even a cable tie.Would there be any problems securing the small end of a cv boot with a jubilee clip?
Didnt it melt and hit the floor?
a mate used a ratchet strap(get me home fix) when his exhaust bracket broke a mile later and it did it again as it meltedhe ended up using wire from a farmers fence. Got him back luckily!
I had to use the correct oetiker clip, they need a special tool to crimp, but I used some carpenter pincers and they worked a treat
Andy
