Is it possible put a magdrill cutter on standard pillar drill
Yep, drill adapters are available. But you will need a very low geared pillar drill to use one.
.Holesaw would be my choice. Drill a suitable pilot hole first, seperatly, and fit a peice of HSS lathe tool on the holesaw arbour where the pilot drill would go. It will give a better quality, rounder hole as it wont wobble so much.
Or you could rough cut a 28mm hole, deburr and round with a carbide burr and then finish with a step drill.
32mm step drill?and then finish with a step drill.
Nope it is quite conviently the largest size on my step drills (from Lidl I think they were) so you can do it in one.32mm step drill?
It would also require drilling from both sides, if the material is 8mm thick.
You're right. Should have checked mine first... 32mm.Nope it is quite conviently the largest size on my step drills (from Lidl I think they were) so you can do it in one.
I've used mag drill cutters in my mill and lathe tailstock, chuck on my pillar drill isn't big enough to hold a mag drill cutterIs it possible put a magdrill cutter on standard pillar drill
it is with the adapterI've used mag drill cutters in my mill and lathe tailstock, chuck on my pillar drill isn't big enough to hold a mag drill cutter
mag drill all day long
Has anyone hereyou wont do it with that plasma and neither will the cut 50 plasma
what you will do is create edges with gouging techniqe
Made or designed a blowback plasma torch that cuts as well as a sl60 on a cutmaster 61? Just wondering . I know the sl60 is 800 dollars . And I just made a start cartridge for a ag60 torch and it cuts like a dream. The only reason I spent 100 plus hours experiencing with my design is because a guy traded me a citmaster 51 for fixing a recoil for a minibike on a Sunday when my shop was closed.but it had no torch and I really didn't want to spend 800 dollars on a torch just to find out the machine was junk. So I sat on it for about 3 years and found that the igbt was bad got a new one from ebay . But it would not pilot . And found out that a spark has to be created .by opening a short circuit . . Anyway I turned an ag 60 into a blowback torch. I have not found anyone online that has made a blowback cartridge or anything . And none of the big name plasma makers don't share that info. . I'm just wondering if anyone thinks that I might be able to pattent my design and make some money . Really want to know how much interest in this I might have please ask around and get back to me.Have used the Cheap ones for one off jobs worked surprisingly well a lot of lube is good.
Cut 80 x 30mm holes in Tube at an angle still working well at the end, only cut 3mm SS with a 25mm 10 holes still cutting ok
