BrokenBiker
- Newport, South Wales
what thickness material are you trying to weld? and is it clean?
if you find that the wire speed is the issue, set your power to whatever you think it needs, then turn the wire speed down to 5 (or half way), try it, it will probably arc once, burn back and stick to the tip, cut the ball off, turn it up to 6 and try again, it will be a bit better, repeat until you get a nice smooth arc and the wire is feeding so its always in the puddle and not either burning back, or trying to push the toech away...then if you go up or down the voltage, you can tweak the wire speed up or down to suit. once you get it set right once and have a few good goes at it, you will get a feel for whether it needs more or less wire, or more or less volts. its all a balancing act along with travel speed
