BrokenBiker
- Newport, South Wales
Tig welding is nothing at all like the other processes...each process has its merit and I can now do all 3 with varying rates of success, but none of them are really the same as the others apart from all 3 need consistency.I asked a few people about getting a tug and they all said I would have no hope of using it if I can’t Mig and stick weld. As I said I’m only a beginner in welding but I will get there. Isn’t that welding for aluminium or can it be used for everything?
For instance, stick welding relies on you being able to keep a consistent rod angle and arc length whilst travelling along the joint, and the rod is always getting shorter so your arc length is always trying to get longer, you have to feed the rod in to match how quickly it's burning away.
Mig requires a consistent arc length and travel angle, while moving at the right speed for how you have it set (once it's set well enough to get a good weld). I'm more hot and heavy, I'll crank the voltage and wire speed a bit higher than normal but I'll get moving with it, some like the wire a bit lower so they can hang about and really burn the weld in. Both have their place though.
Tig is completely different again. You are keeping a consistent arc length and torch angle as before, but now you are also using a foot pedal to constantly micro adjust your amps, and you are usually adding filler manually with your other hand. And yes, tig can be used for everything. You need an AC capable machine for aluminium, most everything else is welded on DC, so steel, stainless steel, titanium, brass, copper, inconel etc. Apart from ally needing AC, everything else is the same with regards to consumables so once you've got the set up, that's it pretty much
I'm nowhere near good enough at tig to advise on it, but I'm getting there slowly, but I certainly wouldn't say you need to be able to mig weld first.
I mostly only make stuff for myself or my father these days
