rikrobson
- Perth, Scotland
There have been a few questions regarding this subject lately.
The Process is quite strait forward.
Connector neck with wiring attached:
Trigger wire on the PCB:
Euro connector clamped up. The gap is a little to big here and it does bird's nest if there id too much tension. This is an old photo and has been ajusted since.
side of the PCB showing the contactor feed wires:
A view of the gas pruge wiring and chocy block:
Should look a bit like this:
- Fit the Euro torch connector
- you will need to remove the old torch. you will be left with the Main current feed wire and the switch feed wire left.
- Mark out the position of the connector and screw holes. The wire feed neck should be in line with the current wire feed.
- Cut out hole.the hole will need to be larger then the brass body, so there is a gap to insulate it from the case.
- You will need to remove the cover that holds the wire liner. this will hold the end of the wire feed tube of the connector and will need to be modified so that the tube is in the correct place. this will need either cutting out or use a dremmel to remove enough plastic so that the tube fits snugly in the correct place.
- You may need to move the wire feed assembly a little close if there is a large gap or you may endup with bad bird's-nesting of the wire if the neck id to far away. againg filing as redrilling of the holes is the answer.
- Fit the connector's plastic housing to the front of the machine ensuring the wire freed tube is in alignment with the mechanism.
- DO NOT fit connector yet and the electrics need to be added first.
- Fit the gas solenoid
- mount the gas solenoid in a suitable place. Mine is in the wire bay on the bottom of the unit. this can go anywhere as long as you remember that the two tubes need to be routed from the gas bottle and to the torch connector.
- if it's a 240v solenoid then you can wire this across the contactor feed. the two wires that are the feed are the two smaller wires that should be in a sheath. one is to the connector on the side if the pcb and the other to the min/max switch. I added a gas purge switched and cut the wires and reconnected with chocolate block.
- connect the two hoses. the arrow will point towards connector and torch and indicates flow direction. the regulator feed hose connects to the input side.
- Add the trigger and main current wires
- Solder or crimp the supplied ring connector to the thick current feed wire.
- The two small wires on the euro connector are the switch feeds. the old toched used the main conductor as one side of the switch and therefore one of these wire needs connecting to the euro connector. I added a suitably sized fork connector with the legs splayed a bit.
- The other wire comnects to the pcb in the same place as the loose wire for the trigger in the old torch. i discarded this and added a small spade connector to the eurotoch wire as there was plenty of reach. you could of course use the existing wire and connect the two.
- The main conductor and switch wire should be added the the stem of the euro connector with the supplied nuts and these adjusted to suit the way you are mounting the connector.
- Final fitting and testing
- Fit the connector to the housing and the wire feed tube should be clamped down with the old plastic clamp that has been modified earlier.
- Fit the torch to the connector and power on.
- pressing the trigger you should hear the contactor close and the solenoid too although this will be quieter. The wire feed motor should also turn. If you gas os connected then you should hear this coming out of the torch. if not got the regulator connected you should be able to blow down the the end.
- Assuming all is well run the wire up the torch and start welding. you may need to adjust the positioning of the torch assy to ensure correct alignment and also make sure that there is not too much tension of the feed rollers and the end of the connector feed tube is not to far away or you will get the wite birdsnesting on you.
