rtcosic
- Warwickshire
If you're doing brakes on vws and Toyota you'll also need 7mm and 11mm Allen keys
And the X200 series Jaguars.
Or are those the ones with the 9mm?
Plus BMW3/5 with E36 chassis, Ford, Volvo, Alfa Romeo, Vauxhall, Volkswagen, Saab & Mini etc.7mm features on BMW motorcycles too.
The day will come I'm sure. that a car/van will be written off because of a failed headlight bulb!. This is why the 'right to repair' legislation is so important. It doesn't just cover the odd washing machine.
I work for an indie now - dealers previously, what you're saying is what was said 15-20 years ago, if you're still fighting the tide, then maybe specialise in 'restorations' etc.- something that minimises contact with cars 1990-on? Timing tools for most chains & belts are cheap enough to reach payback in two or three uses in the main, many 'special fasteners' have tools available on fleabay for low double digits, basic diagnostic tools capable of service functions are in the ~£250 bracket.It's just gone ridiculous now. I've turned down timing belt and chain jobs just because it wasn't worth buying the timing tools. A lot of newer cars need the diagnostic computer to do front pads as well as the rear.
There's no reason for these odd sized bolts from an engineering perspective, they only make sense from a dealers profits perspective.
I work in a main stealers, most of my work now is on EVs, I'm up to date on working on new stuff, my point is manufacturers are intentionally trying to make it expensive for independents to keep up so they have reduced competition.I work for an indie now - dealers previously, what you're saying is what was said 15-20 years ago, if you're still fighting the tide, then maybe specialise in 'restorations' etc.- something that minimises contact with cars 1990-on? Timing tools for most chains & belts are cheap enough to reach payback in two or three uses in the main, many 'special fasteners' have tools available on fleabay for low double digits, basic diagnostic tools capable of service functions are in the ~£250 bracket.
And without dealers, the used car market would have died out long ago.
We are not in the age of Mark 1 Escorts any more unfortunately, where a little bit of experience would get you through, both mechanically and electrically.
Ah right, your post read the complete opposite! I assume the timing belts & chains are 'side jobs' then?I work in a main stealers, most of my work now is on EVs, I'm up to date on working on new stuff, my point is manufacturers are intentionally trying to make it expensive for independents to keep up so they have reduced competition.
A 5 point socket doesn't have any advantage over a regular 6 sided socket other than having to buy an extra socket
I got an indentical - BluePoint one of these....If you're dealing with multi-piston brake calipers, I can recommend a Laser 6743 as a good investment.
What a bag of s==t to drive.The easiest lamps to replace, from a design perspective are the rear cluster on the Peugeot Bipper, 2-3 screws as I recall, pull and all lamps are exposed.
The easiest was the front Headlights on some of the Mondeo models, no tools needed , just pull out 2 locking sliders. Same system also used on some Volvo modelsThe easiest lamps to replace, from a design perspective are the rear cluster on the Peugeot Bipper, 2-3 screws as I recall, pull and all lamps are exposed.
L322 Range Rovers you just open the bonnet, twist off a big fist sized cap from the back of the headlight and voila there you are.The easiest was the front Headlights on some of the Mondeo models, no tools needed , just pull out 2 locking sliders. Same system also used on some Volvo models
On my Regal I extended the opening downwards making starter removal easierHere is a photo taken from this month's Classic Monthly, showing access panels in Reliant three wheelers. This one is a Regal but later cars are very similar. Combine that with a postage stamp size bonnet and much fun ensues...
I dont understand why people are suprised when 7, 9, 11 & 14 are used, they are, after all hydraulic systems as specified in the DIN/ISO standards.And the X200 series Jaguars.
