My understanding is, you can have a normal light switch just inside the door, like any other room. The only requirement is that it must be 60cm from edge of bath/shower.yeah that’s what i was planning on doing so i can have the light on without the fan
just that the other half wanted it on the inside of the bathroom but that would mean a pull cord![]()
interesting…My understanding is, you can have a normal light switch just inside the door, like any other room. The only requirement is that it must be 60cm from edge of bath/shower.
I’m with JW, a bit anti those dirty pull cords or switches outside the room:
Cue frantic arm waving to get the lights back on in mid-read . . .Why not fit an occupancy sensor no switches needed![]()
Can't read a newspaper in the dark...Cue frantic arm waving to get the lights back on in mid-read . . .
Work fitted 'em in the gents . . . the cubicle walls blocked it's "view" . . . seems some people need light to find their own a***![]()
Looks like your classic DIY job!what the f is going on here View attachment 371604
I’ve already terminated the old electric shower feed in the attic so not sure…..I'd keep hacking it out until you find the old rose! It's hard to tell from the picture but could those singles be an old electric shower feed? They look to big for 1.5mm T&E.
yeah been thinking about that, need a new consumer unit n all, would it make a difference if i do the EICR before or after i get a new consumer unit?Based on that it looks like an EICR would be a good shout?
that’s what i thought, the insulation was all charred too!How the hell did that not catch fire?
Have you found the transformer yet?
for reference this is what i’m working with atm
