At work all our keys are chucked in an ice cream tub under the workbench and we have some very pricey old s**t (sorry, classic cars) in for working on.
Next to the Hillman Humper.Swinger Gazelle in there, for the weekend?
1 ton, dually, 8' bed (that never needs to be made), Powerstroke ?Just seen this
I know this won’t help at all
I am looking at purchasing double cab
4x4 pickup
Under no circumstances whatsoever do I want any warranty
I have been reading up on add blue
Incredibly useful suggestion for someone living in Britain1 ton, dually, 8' bed (that never needs to be made), Powerstroke ?
I love my Ford Ranger but the customer care and service at Ford was so shocking, I vowed I would never buy a Ford again.Found more "professionals" handiwork.
This was either Allen Ford or Just Transits.
One of them has used an impact on the 7mm self tapping bolts on the airbox. Every single one is cracked.
Luckily it still pulls down tight.
View attachment 450913 View attachment 450914 View attachment 450915 View attachment 450916
It's knowing who done it Gaz. And proving it.id have videoed it myself and presented it at the ford place
before i hit them with shoddy practice and an intent to damage said vehicle air filter damaged by use of ratchet gun failure to maintain vehicle to exceptable standared with due care and diligence
i would bet the bearings have lost a fair bit of their lifespanYes not good.
Hopefully no damage occured to the box.
So.
Vehicle presented with whining noise on saturday at speeds exceeding 50mph.
Had noticed oil leak on passenger side wheel arch two weeks ago, been too busy to ring ford and argue, let alone be without vehicle.
Removal of FABRIC! engine/sump protector shows lots of oil soaked in. Also 6 missing screws (reckon that's just transits in epping again).
Removal of wheel and close inspection of driveshaft (replaced october/november 2023 with clutch by allen ford) revealed leak from driveshaft oil seal.
Drained gearbox oil = 0.35L recovered.
Have just refilled with 2.2L of 75w FE as per @premmington recommendation.
It's a better than fair chance that it's not "The Dealer" per se, but the standard of work is massively dependent upon the spanner monkey (& what mood he's in) on the day.My guessing is the penny pinching sods at ford did not replace oil seal when they done clutch and new driveshaft, hence slowly leaking until i had tyres changed an noticed, fast forward two weeks and now practically empty it started whining.
Can they be pulled out in situ?I would be doing the driveshaft seal soon - They not too bad to do! Buy a geniune Ford one - it is gods own work to get a pattern Febi one in.
Basically you don't have the same rights as a business:commercial customer as a personal consumer.I couldnt see an answer earlier in thread, were you unable to reject it?
