You can measure it with a meter with no load.
It may not be very accurate with a digital meter. An analog one will actually work better on transformer units. Digital ones tend to measure peaks.
It still may need a small load to get the effective voltage.
I'm still not convinced about spending alot of money on an inverter that may only be occasionally used.I wanted to ask a few questions about the cheap "buzz box" welders without anyone taking offence.![]()
I've read the pros and cons for and against them, but for the first time user/DIY'er with little interest in highly expensive machines, what can these cheap AC only welder do and what would they be realistically used for? Can this be answered in a neutral manner?![]()
I'm trying to be open minded about them and perhaps I did judge the ones that I experienced too harshly.I'm still not convinced about spending alot of money on an inverter that may only be occasionally used.
on the top end, this gives you a minute of welding for every ten.... which even for DIY use is hard going, for a little more money a much better buzz box could be bought, or even an S/H oxford, say around the £50 mark.....occasionally a weekend of work on the miniature railway.
Chris.
I must admit I did have major problems with the rods sticking to the job, but I think that was my fault to be fair to the machine.
I must admit I did have major problems with the rods sticking to the job, but I think that was my fault to be fair to the machine. I did do some beads without it sticking, but I didn't use anything larger than the 2mm rods provided with the welder (running @ 65A). The rods sticking did put me off somewhat as well as the other things.
Regarding the selection of rods, there's not much choice round here from doing a search on Google. I'll check my local Thomson's Directory to see if it comes up with something. I've got a local Halfords that selling those SIP rods @ £3.50 for 10. I know that most people in here recommend to stay away from the car auto shops type rods, so I'll definitely keep that in mind. I defer to those with greater experience than me in such matters.![]()
Hey Muggins. There's a BOC in Irvine. They should be able to sort you out for rods.
BOC Gases
6 McMillan Place
Oldhall West Industrial Estate, Irvine, KA11
01294 311379
