http://www.mig-welding.co.uk/forum/showthread.php?t=8046
Same guts, different colour casing from what I can see. Mind you, I never got to see inside the Aldi one - only through the air vents.
Many thanks for the link. I hadn't previously seen that thread or photos. I fear, however, that there may be a bit of 'playing to the gallery' here. The group that comprises this forum has decreed that Powercraft welders are rubbish, so how many people are going to say anything nice? I look forward to buying one to see for myself.
Simon, who started that thread said: "not exactly the most sophisticated machine in the world, and a lack of smoothing caps... and that fan is absolutley pathetic, next week's task is to source something a little bit more substantial, hopefully make it run a bit longer before cutting out"
1. Who said it needs to be sophisticated? This is a fundamentally simple design. That's one reason why they work so well and can last so long.
2. No arc welder of this type ever has smoothing caps so this comment helps to run down the welder even though it's a complete red herring.
3. The fan doesn't look pathetic to me. It probably does a perfectly reasonable job, even though 'the bigger the fan the better' of course. None of these sub £100 arc welders will have a much bigger fan.
4. If he was running it on max then it will cut out, just like a Portamig welder or most other transformer based welders, apart from Oxford types, if they are run for too long.
