eLuSiVeMiTe
Lol. They come up on the bay around 80 notes. Set a watch up. Mine was freeThat can rest there for a little longer
Bob
Bob
I have a perles concrete mixer , very good quality tool.Curiosity,no ones mentioned a perles product?
Bosch codes are not too difficult to understand
G stands for industrial
W stands for angle
S stands for grinder
Exactly , I couldn't remember how were wrote the various German wordsPerles? Don't mention that name to me. Bought a Perles angle grinder at Toom Baumarkt in Germany in 1980. Cost about 150 DM, which was a lot to me then. Never used it until 1990, when I had to cut the rusty sill off a Mini. The grinder ran for 5 minutes and then let it's white smoke out.
Perles tools were made by the Yugoslav company "Iskra" - which means "spark". In my case, too many.
There's a good German angle grinder company that is neither Metabo nor Bosch : Flex.
https://www.flex-tools.com/en/
They invented the angle grinder in 1954, and often any angle grinder is called a "Flex" in Germany ( cf."Hoover" vacuum cleaner or "Thermos" flask ). Flex grinders are very capable - e.g. they offer a 5 inch grinder with a 1700 Watt motor, soft start, NVR switch, variable speed, brake, and constant speed control.
That would be: Gewerblich .... .Winkel .... Schleifer
As title, 115mm 240v no matter what I buy the god damn things die within a year. It’s always the same thing, the armature starts growling bit by bit. I’ve had possibly 13 grinders in ten years ranging from £10 budget to £70,dewalt, Bosch blue Makita and more.
I just can’t find one that will do the duration of the warranty.
I use steel 4.5” cutting discs and those twisted nasty nasty wire wheels so it’s metal dust that I think is the killer. I can’t use any thing too vicious as I use it single hand and it needs to be narrow body with one hand easy switching.
Anyone on here using one everyday on metal that’s been impressive?
I usually use to put just enough pressure to avoid any bounce from the wheel .There is a good chance people put too much pressure on the grinder forcing it to cut rather then letting it cut slower at its designed pace hence they heat up to much and eventually self destruct
I think that your thoughts are good.You’ve got to look at it this way.
It’s either a tool to do a job or an ornament you never want to replace.
Tools wear out.
If I’m grinding something I want to get it done, you can’t stand there for half an hour letting the grinder do the work, you’ve got to put some force behind it. Inevitably yes this is going to be hard on grinders and that’s just something you’ve got to accept.
It’s very different when someone is telling you their £35 grinder from Aldi has lasted 20 years but hasn’t ever worked on anything thicker than rusty car body work once a week.
FeinI still need to replace mine with an over the counter modern day tool after all that's said and still have no idea what to buy
That is impressive
