I don't think so much it's draining power or all of them would have the same problem it's just some of the battery yes Need a charge but in the end 3 out of 30Even just disconnecting the batteries might be enough to preserve the charge. If access is difficult could you put a remote battery switch somewhere?
ok can you post a few linkys to the ones you got peoples please might give one a try it only has to recover 2 batterys to pay for its self
is the noco ? better ?https://www.amazon.co.uk/CTEK-Batte...007326&hvtargid=pla-303286758601&gad_source=1
Can be bought cheaper if you shop around.
Another useful feature is that if the charger is switched off it will resume charging where it left off once powered on again.
I have the 10 amp version of that ctek bit otherwise +1 to your post.+ 1 for that CTEK. I have several of them. They do have a good recon feature if the battery is caught in time. It's not a miracle dead battery reviver but as close as you'll get as there is no such thing as bringing back dead car batteries.
I might suggest also that the ONLY way to tell if a battery is any good or not is a quality modern battery tester. Such as Topdon units. Highly accurate. Eg
Sorry for the sideways pic but that's just an example of the readings. If it says replace then the battery is stuffed in my experience and only fit for the bin. 50% health or above is worth looking at. New batteries tend to test at 100% or over the stated CCA which is also useful to know what you are buying.
Here's a review of them.is the noco ? better ?
we have 30 ish buggys so time taken removing keeping charged and then refitting once needed again far out ways the cost of say 3 batterys every year even if you say 6 batterys replaced it would be close
topdon chargers got a link ? and do so much ? im not hoping to revive 12v down to 1 volt batterys here just save a couple if we can if the batterys are 60 each the repair charger is 120 but works on 2 batterys a year for 5 years its worth doing but if the repair bit is tosh and does realy nothing its not woth it
its not that they dont get maintaned they do but the cost of removing the batterys or random charging them over the whole winter paying a bloke minium wage for a few hours a month to fart around when he could be doing some thing more construtive to save £200 on 3 batterys all i was asking was do the charges work if they do and saves 1 battery a year it pays for its self quicklyNo offence intended, but if the business can’t afford the time to maintain the equipment, you have to question the viability of it.
Just doesn't make much sense to me.
thankyou seams the ctek might be the one to go for will ask if we can try one at least its 1 more charger that we can use at worst if does work then a bit of a money save could beHere's a review of them.
https://carbatterygeek.co.uk/noco-genius-5-uk-vs-ctek-mxs5-0/
Both are top quality chargers and are very similar in function and price.
There are slightly different extra functions so pick whichever suits you best.
The recovery modes on the ctek are more thorough so it might suit better.
I bought the ctek first and it suited my purpose until I needed to charge 6v batteries. Then I bought a noco to charge them.
I've got to say, I can’t really see the argument for letting the batteries die.
They are already spending time putting the buggy back into service after winter – so refitting a battery is going to add an extra 5 to 10 minutes top?
I’d also assume they would have some sort of procedure for laying the buggies up for winter - Removing the batteries, unless they are incredibly difficult to get to, really shouldn’t add much extra time.
All my bikes have one of these on the battery to simplify chargingThey could even add some anderson type connectors (also on the charger) to make changing out faster,
