Nowhere at the mo!
Test fitted the engine and found this
i've got to fit a thermostat housing between the engine and bulkhead so a bit of a space issue!
Rather than cut the bulkhead and lose the heater i'm moving the engine forwards
changing to the longer imput shaft type 9 which has a 32mm longer input shaft, that coupled with an inch longer autobox prop should give me enough clerance
Since the zetec transplants being done on a budget of £300 i couldnt find a long input shaft type 9 cheap, did however pick up a cheap 4x4 sierra one which i'm halfway through converting to 2wd.
Running stock injection and management purely to keep the costs down and to get the car running!
The v6 type9's are getting scarce now, even the bog standard type9's are getting a bit thin on the ground, I even had to "pay" for my last one *gasp*.
I didn't know the auto-prop was an inch longer than the stock one, that'll save you over £100.
But, having said that, there's plenty of space for the theremostat housing.
