I've never liked the idea of the Hamer lift. How do you raise the thing? do you have to run laps around it doing one click at a time on the jacks till the car is at height? As for dismantling and storing it - I can see it easily taking an hour to have the thing put together and the car in the air. The usual decision would likely be "stuff that, I'll put it up on a couple of axle stands". By the time you wish you'd assembled the lift the car's in bits and can't easily be moved out of the way to assemble the lift and then shoved back on it
If what ever you get has to go through the house to be stored it's ramps of some sort only, anything g else is going to be hefty and awkward to move aroundjust looks like pressed steel to me...armco may not be the best material, the shape wouldnt allow space to jack under the sills if needed...
im thinking just make the actual ramps, a bar similar to the tube in the video for jacking the front up then use axle stands under the front so it could be height adjustable if needed...i have room to store the ramps full length in the garden
I bought a cheap car transporter trailer (£400) for a house move and then noticed it was tall enough to drive the car onto it and slide underneath with a lot of room to spare. Middle of it is open so easy to sit up and get to the underside. What about a tipper trailer with the same sort of hole in the centre?
Summat like this and then put an open bed on it?
http://www.ebay.co.uk/itm/tipping-trailer/272295361791?_trksid=p2047675.c100005.m1851&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=35923&meid=d2f8c9e488f74dbb904635efc637d936&pid=100005&rk=1&rkt=6&sd=322166204169
Still won't get it high enough to allow working standing underneath it.make some large car ramps or big axle stands and a good big jack to get car up on them
I am redoing my drive soon and I am considering making something robust and inset concrete footings to take the weight etc.'Store' it in your parking space, park on top of it...
In fact for sensible home use I don't think it's possible.
My brother in law has a scissor ramp and it's good for wheel and bearing work but underside not much use.
The best way IMHO is to build a good solid version of the ramp with jacking rams that a guy on her shared his design with us.
He has no land where he could dig a pit, only 1 allocated parking spaceIdeal solution is a pit then.
