slim_boy_fat
- Scottish Highlands
Easy done
Thanks, but I'm still mad at myself.
Easy done
I finished turning some screws last week, drilled and tapped a jig for them so I could cut the slot in the head. This week, I couln't find the jig or one of the screw blanks.Thanks, but I'm still mad at myself.
Stick a dti on the chuck face
Cock 12 then 6 adjust to be in the middle
Clock in 3 and 9 adjust
You are now aligned
Gotta be very careful doing that because the stem of the DTI mount will bend down under self-weight.
I usually use a file just in case.Just to update this. I reckon it's down more to operator being stupid than severe wear in the Myford.
Having sorted the East > West horizontal alignment, I applied logic to things and, having started again from scratch with a fresh work piece I noticed that when facing off there was a very small [i.e. tiny] 'pip' left, which would be enough to divert a small drill at the start of operations. Adjusted the height of the cutting tool to spot on centre height, and that seems to have sorted things .
Appreciate as always all your inputs/suggestions
EDIT: note to self - use a centre drill in future, stupid!!
We wouldm't be human if we didn't make mistakes on occasion.Thanks, but I'm still mad at myself.
CoAx is a good choice for that. Bought one for aligning the VDI turret I made for my lathe. A friend borrowed it, he still has it In fairness I said I wasn't in a hurry for it backCertainly can indeed but a stern dti base is worth owning even though they are a faff to set up
